Hello Expert ,
I am learning data scientist with Python ,R ,Machine learning etc. stuff , So can Thingworx provide facility for data scientist ? So I can use TW for data scientist. Or some facility provide like Machine learning , R etc.
regards,
Mayank
Hi Mayank,
I agree with Carles, You can try a free 30 day trial of ThingWorx Analytics at this link if you are interested in trying it out first hand.
John
Look at ThingWork Analytics
Hi Mayank,
John
Hi Mayank,
TWX Analytics is to bring data science to the masses. Maybe you're a bit over educated for TWX Analytics. You will see that TWX can bring up fast results in a fraction of time compared to R and with much less required knowledge. Anyhow I can promise you will miss the ability to fine-tune and trick-it. Anyhow I also suggest to use the free evaluation and get an idea how far you can get today with limited effort.
Stefan
Mayank Patel You are using languages like Python and R to design and Program your analytics engine. Thingworx provide integrated mechanism for the same .
It would be of great help to you to compare your result coming from your algorithm , to that of Analytics engine used by Thingworx .
You can provide us the feedback , if you find the Thingworx Analytics useful smart.
Hi Mayank ,
If you want to test using ThingWorx Analyticsplease refer to the below link for a quick start :
Homepage - Developer Zone : ThingWorx
Best Regards,
Amine
