How can i use data science methods in TW?
mpatel-21
2-Guest
Hello Expert ,
I am learning data scientist with Python ,R ,Machine learning etc. stuff , So can Thingworx provide facility for data scientist ? So I can use TW for data scientist. Or some facility provide like Machine learning , R etc.
regards,
Mayank
jgreiner
(To:mpatel-21)
Hi Mayank,
I agree with Carles, You can try a free 30 day trial of ThingWorx Analytics at this link​ if you are interested in trying it out first hand.
John
Look at ThingWork Analytics
jgreiner
(To:mpatel-21)
Hi Mayank,
John
Hi Mayank,
TWX Analytics is to bring data science to the masses. Maybe you're a bit over educated for TWX Analytics. You will see that TWX can bring up fast results in a fraction of time compared to R and with much less required knowledge. Anyhow I can promise you will miss the ability to fine-tune and trick-it. Anyhow I also suggest to use the free evaluation and get an idea how far you can get today with limited effort.
Stefan
Mayank Patel​ You are using languages like Python and R to design and Program your analytics engine. Thingworx provide integrated mechanism for the same .
It would be of great help to you to compare your result coming from your algorithm , to that of Analytics engine used by Thingworx .
You can provide us the feedback , if you find the Thingworx Analytics useful smart.
mchehaibi
(To:mpatel-21)
Hi Mayank ,
If you want to test using ThingWorx Analyticsplease refer to the below link for a quick start :
Homepage - Developer Zone : ThingWorx
Best Regards,
Amine
