How can we set the properties of widget from the script side?
hraj1
I have multiple instruments to be plotted on the label graph and I want to set the returned infotable in my script to the Data source property of label graph. i want it to display same parameters of multiple instruments.
1 REPLY 1
ttielebein
(To:hraj1)
Whatever infotable you bind as the data source to that chart should automatically populate the graph labels. Is this not working for you?
