Hello
It is strange to adjust the text size of the list widget.
A text size of about 24 sizes can be handled appropriately through listFormat.
However, text sizes larger than 24 are displayed with the upper part of the character truncated
Currently I am using version 7 of ThingWorx.
Cause this is the problem ??
Or, if you are using a list widget over than 36px text size, please share it.
Thank you.
Hello @CHASEONHO,
In the list widget properties, ListFormat will be there. By giving custom style and adjust text size in that you can make it visible.
The list with 42 as text size is viewed in UI as given below
However, this option is available in Thingworx 8.2 version. I will check and let you know in 7.4 version.
With regards
Yedukrishnan
Hi @CHASEONHO is it possible to share a screenshot on how the text is getting truncated?
Cropped as you see.
The list display all test, but didn't display all text selected items
Hello @CHASEONHO,
This option is available in Thingworx 7.3 version. Please check it.
With regards
Yedukrishnan
Hello @CHASEONHO,
With regards
Yedukrishnan
Thank you!
If it is English, it will be displayed.
In case of Hangul, if the text size is more than 28, it will be cut and displayed.
A friendly answer Thanks again.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
