How do I use the paging widget?
SOLVED
Highlighted
Participant
I am using the Advanced Grid for displaying my data and would like to utilize the Paging widget to query my data. I am not sure how to bind it's properties, is there anyone who can help us?
I have attached a screenshot of the properties it contains,
Thank you
Rafay
1 ACCEPTED SOLUTION
Highlighted
Re: How do I use the paging widget?
Hi @rj14
I just came across these articles which might be helpful for you to get information on paging widget.
CS308711
CS311123
Vibhuti
4 REPLIES 4
Highlighted
Hi @rj14.
We will be providing some updated information on the Paging widget in the next few weeks.  I will flag your post and follow-up to advise once it becomes available.
--Sharon
Highlighted
Thank you
Highlighted
Hi @rj14
CS308711
CS311123
Vibhuti
Hi @rj14.
Since information has now been published regarding the use of the paging widget, if would be appreciated if you would mark the appropriate response as the Accepted Solution.
If you still have questions, please let us know.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
