How run the Apache Zookeeper server as Background service in Windows
vi1
I am making Thingworx HA.
I was able to run the Zookeeper server from command prompt on Windows.
I would like to run as a background service instead and also start automatically without start manually or Login system.
I was able to create the service using below command.
sc.exe create ZookeeperService binPath= “C:\zookeeper\apache-zookeeper-3.5.5\bin\zkServer.cmd
Service is created but it is not started and an the getting error. Please refer the attached screenshot
Could you please help on how to run background service.
Thank you in Advance.
Latha
vi1
(To:vi1)
I am able to do with NSSM. Thank you for your suggestions.
Latha
raluca_edu
(To:vi1)
You can try with AlwaysUp as in this link: https://www.coretechnologies.com/products/AlwaysUp/Apps/RunZooKeeperAsAWindowsService.html
Hope it helps,
Raluca Edu
vi1
(To:raluca_edu)
Thank you for replay.
Alwaysup is not free software.
Is there any otherway i can run Zookeeper as background service.Service is created as Background but not able to run the service.
I am getting the error "Error 1053: The service did not respond to the start or control request in a timely fashion".
I have updated "ServicesPipeTimeout" and also did the ccleaner. Still getting error.
Could you help me on how to resolve.
raluca_edu
(To:vi1)
You can also try with NSSM: https://nssm.cc/download As far as I know, this one is free.
Can you check Events log and search for the error you have to get more messages related to the error?
Thank you,
Raluca Edu
vi1
(To:raluca_edu)
Thank you for information. I will try your options.
Latha
vi1
(To:vi1)
Latha
