I have a service to get live property values. How can i create an alert on this service when the values increases on a threshold.
If you want to use the built in "Alert" function on the thing entity then you would have to first create a property for the value which you want to send an alert for.
Here you can read more on how to use the Alert function.
Jens
Jens
