How to Execute Stored Procedure Which Has Two Result Set in Thinworx
sdaram
Hi All,
I have Stored Procedure that will return Two Result Sets . I am Trying to Execute This Stored Procedure from Thingworx Service But unable to get results.
While I am running stored Procedure in MSSQL Database i am able to get values in 2 result set but when i run Same Procedure in Thingworx Service nothing is coming.
Please let me know How to resolve this Issues. Looking for positive response.
Regards
Spandhana
4 REPLIES 4
sdaram
(To:sdaram)
In SQL Server When I execute stored procedure it is getting result in 2 result set
In My scenario the above values i have to display in Datagrid in Thingworx Composer.
Steps I have done.
1)I have Created a Datashape Which have all columns which we are getting from Stored proecure.
like PLID,PPId,UserId,PathId(resultset1 columns) ..................................................TargetProperty,PropertyValueType,PropertyValue....................................etc(ResultSet2 columns) in single datashape.
2) I have Created a Service to call my stored procedure.  by mapping my Datashape  "KPI_Main_Grid_DataShape" to service.
The Stored proecure Expecting some input parameters i am passing default values to execute stored proecure.
Note:- Here my issue is i am unable to get values from stored procedure when i call from thingworx service.
I Hope everyone understand my scenario looking for help to resolve my issues.
Thanks & regards
Spandhana Daram
sdaram
(To:sdaram)
Hi All,
please look into my issues . Please do needful .Thank you
Thanks&Regards
Spandhana
mlohokare
(To:sdaram)
I was also facing same issue of "not able to run package" from Thingworx service with below command,
EXEC del_pkg.del_tbls
(ORA-00900: invalid SQL statement)
but, I changed the command as below
CALL del_pkg.del_tbls()
it gives me result as - ( null), but it actually works at backend.
This might gives you some clues.
Mahesh Lohokare
nkhose
(To:sdaram)
Is there any scope to get the result set from the stored procedure as Union of the two result set ? If  so you can bind to infotable ,Else i think you need to separate the two result set to have two different infotable and then union both infotable into one at thingworx side
