As you can see in the below Column, there is an Sorting/Arrow icon in the Grid widget, I want it to disappear from that Field...
Thanks !!
There is an enhancement ticket already open for this, refer article. As per the comments on the Jira there is no plan to update the legacy grid widget with this enhancement. I checked but could not find any custom solution for this. Recommend using the advanced grid because the legacy grid has already been deprecated.
Sachin
You will have to uncheck the EnableSorting property in advanced grid setting. This will disable the sorting as well.
Sachin
Hi @SachinSharma ,
Thanks for the Quick Reply, But I am not using an Advance Grid.
@CarlesColl, do you have any solution to it ?
Thanks !!
Sachin
