Hello everyone,
I have a service that returns an infotable with a column that contains multiple rows with infotables.
I want to use a collection widget to display the nested infotables dynamically (depending on how many rows there are).
The user is supposed to select something in one of the infotables. This selection, I want to use!
This were the bindings I created. But in the label which should display the selection data, nothing is displayed. Is this a bug or am I doing something wrong?
Note: please disregard [object object], I have set DisplayField, StateField, ValueField but for privacy reasons I took the screenshot before I set it.
I would appreciate any help!
Thank you!
Thank you for your help! Sorry, I described it maybe not right.
I want to pass back what was selected in the static collection mashup, to the "main" mashup that contains the collection widget.
MashupGlobalPropertyBinding property of Collection widget can be used to achieve above mentioned functionality.
Hope this Helps!!
I don't understand how I can use MashupGlobalPropertyBinding to pass back what was selected.
I have done the following steps:
1. InfoTable property "myInfoTable" with a DataShape that has one column named "InfoTable" of Type InfoTable.
2. Created Responsive Base Mashup with Collection Widget and Static Mashup with a List Widget.
3. Responsive Base Mashup:
4. Static Mashup:
5. Responsive Base Mashup
"InfoTable" : "infotableData"
--> Success, the responsive mashup displays 2 Lists, one for each row of the nested InfoTables
But this is where I'm then stuck. I want to use the SelectedItems properties and pass back to the responsive mashup, whatever the user has selected in one of the lists. How can this passing back be achieved? Or is collection widget only for displaying data?
Property defined in MashupGlobalPropertyBinding will create property which can be bound (in both ways => child to parent mashup or parent to child mashup)
{"selectedData" : "STRING"}
Hope it helps!!
Hi Ashrita,
thank you so much for the steps!! Worked perfectly for passing the String data!
Do you also know how to pass back a whole InfoTable? The format {"selectedRow": "INFOTABLE"} with a MashupProperty called "selectedRow" of type InfoTable (receiving selectedItems from ChildMashup) doesn't work.
I assume one also needs to give the DataShape name in the JSON Format.
I have found other users asking the same in the forum, but no solution was found.
