How to achieve excel like pivot functionality in Thingworx?
abhide-4
Tried using Pivot function, but it has limited functionality with dependency on timestamp property. So cannot achieve excel like pivot capability. Are there any other ways/options to achieve the same in ThingWorx?
var result = Resources["InfoTableFunctions"].Pivot(params);
Below is a sample working code as a reference for anyone looking to generate excel like pivot table successfully in Thingworx.
//1. Get the distinct list of column1
var params = {
t: result2 /* INFOTABLE */,
columns: "split" /* STRING */
var UniqueSplitList = Resources["InfoTableFunctions"].Distinct(params);
//2. Get the distinct list of column2
var params = {
columns: "stage" /* STRING */
var UniqueStageList = Resources["InfoTableFunctions"].Distinct(params);
//3. Create an empty infotable using the target DataShape for the desired pivot table
var params = {
infoTableName : "InfoTable",
dataShapeName : "Stage_Splits_DataShape"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(Stage_Splits_DataShape)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
//4. Loop through unique Column1 and Column2
for (var x = 0; x < UniqueSplitList.length; x++)
    // new row entry object
var newEntry = new Object();
    logger.warn("UniqueSplitList = " + UniqueSplitList.split + "UniqueSplitList.length = " + UniqueSplitList.length);
    newEntry.split = UniqueSplitList.split; // STRING - isPrimaryKey = true
    for (var y = 0; y < UniqueStageList.length; y++)
   //Generate the query to count occurrences in column2 for a given value in column1
        var query2 = {
          "filters": {
            "type": "AND",
            "filters": [
                "fieldName": "split",
                "type": "LIKE",
                "value": UniqueSplitList.split
                "fieldName": "stage",
                "type": "LIKE",
                "value": UniqueStageList.stage
        var params = {
            query: query2 /* QUERY */
        // result3: INFOTABLE
        var result3 = Resources["InfoTableFunctions"].Query(params);
        //Calculate the counts for the current row
  if(UniqueStageList.stage == "two")
            newEntry.no_two = result3.rows.length; // NUMBER
  if(UniqueStageList.stage == "three")
            newEntry.no_three = result3.rows.length; // NUMBER
  if(UniqueStageList.stage == "four")
            newEntry.no_four = result3.rows.length; // NUMBER
        //Calculate the %s for the current row
        if(y == UniqueStageList.length -1 )
            newEntry.pct_two = Math.round(100 * newEntry.no_two/(newEntry.no_two + newEntry.no_three + newEntry.no_four)); // NUMBER
            newEntry.pct_three = Math.round(100* newEntry.no_three/(newEntry.no_two + newEntry.no_three + newEntry.no_four)); // NUMBER
            newEntry.pct_four = Math.round(100 * newEntry.no_four/(newEntry.no_two + newEntry.no_three + newEntry.no_four)); // NUMBER
         //Add this entire row to the result infoTable
         result.AddRow(newEntry);
Not as far as I know. But you may cook data to convert non timestamp fields to timestamp field:
Category = A = new Date(0)
Category = B = new Date(1)
var params = {
var params = {
var params = {
        var query2 = {
          "filters": {
            "type": "AND",
            "filters": [
                "type": "LIKE",
                "type": "LIKE",
        var params = {
