Hi Developers,
I use schedule widget to see data of 3 days.
as default, we can see all data.
I know we can set start date and end date and once I set both date, I can see restricted amount of data though, I'm not sure on how to add scroll bar in X-Axis to see remaining data.
Could you let me know we can put scroll bar in X-axis ?
Default : display all data
Ideal : can see only data of a day.
scroll to see data of after the day
Hello @Yoshihiko.N ,
Pls check the following article for your reference:
https://www.ptc.com/en/support/article/cs67798
Let me know if you know something else.
Regards
Bhawna
Unfortunately, this cannot be achieved. But I would like to request you to report the case with the PTC technical team so that RnD can look into it.
Regards
Bhawna
Hi Bhawna,
Thank you for your reply.
could you let me know on how to report the case with the PTC technical team ?
Regards
Bhawna
