How to add state definition greater than condition?
bgupta-2
How can I add greter than condition in state definition?
Example if   state <30 green
state >35 red
else yellow
3 REPLIES 3
supandey
(To:bgupta-2)
Hi Bhuwaneshwar, could do that with multiple states with less than target values. Have you already tried that?
Hi Bhuwaneshwar,
you can create State Definition only with "Less than" filters. The states are overwriting each other, so in your case it should look like this:
And the final result:
I hope it helps.
Best Regards,
Adam
