How to add users to view blog
svisveswaraiya
I created a blog in a mashup, where only I am able to edit and comment on it. I dont know how to proceed further.
I want other users that I have created also to view and comment on the blog I created.
How can this be made possible?
Please provide some guidance.
V Shalini.
1 ACCEPTED SOLUTION
If you go to the Blog Entity in Composer and then look at Services you will see all the services associated with a blog.
They will need the ability to execute certain services like: GetBlogEntriesWithComments
You should use Override for this to specifically grant these permissions.
5 REPLIES 5
As with any mashup it is all about the Permissions and Visibility settings.
1. Give the users the link to your blog page
2. Make sure that those Users are in a Group that has been giving the appropriate permissions to your Blog Thing Services
Note: Do NOT give the users FULL rights because that would allow them to delete/edit
Only give them the Get services and the Add Comment services etc.
Hi PaiChung,
Thanks a lot for your reply.
But still I am not so clear about it.
should I give permissions to users like this so that they can view the blog from their credentials?
In this run time, I should be giving only Property read right?
Hi PaiChung,
I just tried to give permissions like runtime and designtime after which,
When I logged in the User and tried to open the mashup which has the blog it shows me a status message like this:
"Not authorized for ServiceInvoke on RequestEdit in testBlog"
How should I give authority for ServiceInvoke on RequestEdit? Should I give it in the runtime?
Please give me some idea to make it work.
Thanks PaiChung,
It worked for me.
