How to adjust image using value display widget in Thingworx 9.2.
MM_9023322
Hi all,
I want to display an image using an value display widget. Currently I am using Thingworx 9.2 version.
I have bind the service output to value display. The height and width of the value display is 130 and 171 respectively. When I view the mashup, the size of image within the value display widget is too small. I want the image to be fill within the dimensions given for the value display. I don't want to increase the dimensions further.
Please suggest, how to adjust the image within the given dimensions.
Thank you in advance!!
Here are some similar questions previously:
MM_9023322
(To:VladimirN)
Thank you for your response, but unfortunately none of these above solutions worked for me. I am using Value display widget to view the image.
Please suggest!
slangley
(To:MM_9023322)
Hi @MM_9023322.
The image widget might be a better choice for this as it provides more options for scaling.  You can read about it here.
--Sharon
