The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I need to block some particular properties value from change via REST call due to security reasons. How can I do this?
Set Read-Only option for property block it from change from anywhere (Services, Subscription, etc.)
Run Time permission property overrides - solve it.
Does making them read only help?
Else you will have to use permission overrides
You should set correct permissioning for the remote user with Run Time permissions over those properties that's all.
