How to change color of vertical slider when value changes?
akesana
We want to show different colors based on the value.
Up to 30 we want to show one color, if it crosses 30 changes to another color, crosses 70 changes to some other color.
Could anyone help me to achieve this functionality
ankigupta
(To:akesana)
Hi Anil Kesana​,
Vertical Slider widget doesn't have State based formatting available so I don't think this could be achieved with the Core Vertical Slider widget.
You may consider creating your own custom widget. You can use the existing widget as base.
I hope it helps.
Hi Anil,
If I understand well what you to archive you should look at Shape widget, you will be able to set State Formatting and fill it on a %.
Best Regards,
Carles.
