How to change font type
bgupta-2
Dear Team,
How to change font type? As in style there is no options for font changes.
Thanks in advance
9 REPLIES 9
supandey
(To:bgupta-2)
Hi Bhuwaneshwar, for which widget are you attempting to change the font?
supandey
(To:supandey)
Not sure if you have already seen this extension called Font Labeling available for download from ThingWorx Marketplace
That extension are work for label only. I need for all widget level.
supandey
(To:bgupta-2)
As far as i know you will need to call a custom CSS style sheet to apply different font styles.
Hi Sushant,
Can you help me regarding this how to call custom css in thingworx.
jamesm1
(To:bgupta-2)
Do you want to change the font for the entire platform and all mashups/widgets? This is possible with an extension that includes the font you wish to use as an UNKNOWN resource type in the meta data, and including runtime CSS such as:
@font-face {
  font-family: 'ITCBLKAD';
  src: url(ITCBLKAD.TTF);
  font-weight: normal;
  font-style: normal;
    font-family: 'ITCBLKAD', Arial, sans-serif !important;
yonkim
(To:jamesm1)
James
Could you explain with more details or share the extension you mentioned.
bgupta-2
(To:yonkim)
Hi James,
I need for widget.
HI All,
Font Labeling Widget is available at ThingWorx IoT Marketplace  for this case.
Thanks & Regards,
Sathishkumar C
