How to change the edit from grid widget in Thingworx 9.3
MM_9023322
Hello everyone,
Currently, I am working on Thingworx 9.3 version, and I am recreating a mashup that contains a grid widget. In thingworx 8.4.3 the edit function from the grid was more convenient than in Thingworx 9.3. I want to change the UI of this grid from Thingworx 9.3 to look the same as the older one. I have attached the file that shows the UI of both the grid.
Please let me know how can change the edit functionality from this new version.
Thank You
slangley
(To:MM_9023322)
Hi @MM_9023322.
Can you confirm which grid widget you're using in 9.3?
--Sharon
MM_9023322
(To:slangley)
Hi @slangley ,
I am using this grid widget
slangley
(To:MM_9023322)
Hi @MM_9023322.
We've played around with this some and have a couple of questions:
  • What is your intent with the row selection?  Are you allowing edits or selecting for some other purpose?
  • Have you tested without using the checkbox in 9.3?  It doesn't appear that it's needed but that may depend on the use case.
--Sharon
