How to change the tooltip format on Line chart
MM_9023322
Hi team,
I want to change the default tooltip format on the Line chart. We have a requirement where we are using the Line chart as a step chart on Thingworx 9.3 version. The default tooltip is "Wed Mar 02 2022 02:59:16 GMT +0530(India Standard Time), Signal:1", which I want to change to "2022-03-03 02:59:16, Signal:1". I came across the Localization tables in TW where you can customize the tooltip. By following this link https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/CreatingCustomChartTooltips.html
I created a new token, now I am getting "Signal:1" on the tooltip, but I am not able to understand how I can customize the Timestamp. The default token is "${label}, ${series}: ${value}".
Thank you!!
slangley
23-Emerald II
(To:MM_9023322)
Hi @MM_9023322.
The release of ThingWorx 9.3.4 is now available on the PTC download site.  Hopefully, it will resolve your issue.
--Sharon
14 REPLIES 14
slangley
23-Emerald II
(To:MM_9023322)
Hi @MM_9023322.
You may have to change the way the data is stored in order for the tooltip to display per your requirement.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @MM_9023322.
Something else.....I assume you already have the XAxisType set to Date/Time.  If so, there is an XAsixDateFormatToken that may work but you will have to play around with it.
--Sharon
We want to change the datetime format on the hovering to only Date or remove the timezone from the tooltip . Please let me know if you have any input on this.
@slangley
slangley
23-Emerald II
(To:slangley)
Hi @MM_9023322.
We recommend opening a case for this.  In our testing, it doesn't appear to be working as expected.  Please let me know if you would like me to open the case on your behalf.
--Sharon
Yes please
slangley
23-Emerald II
(To:NG_9802022)
Hi @NG_9802022.
The case has been created under your credentials.  You should be receiving an email with the case number.
--Sharon
LP_10027711
(To:NG_9802022)
Did you get a solution for this? i am looking for the same. thanks!
no
HM_10184200
6-Contributor
(To:slangley)
Excuse me @ MM_9023322  , have you found any solution for this? Im also facing the same issue
@HM_10184200, not yet. We have raised a ticket with PTC support, we are still in discussion with them.
@MM_9023322   I just found a trick, to modify the timestamp in the tool tip, I create extra field on the infotable, that field is to store the customized timestamp. To select those timestamp, I use ${Data:timestampForToolTip} on the ValuesToolTip.  timestampForToolTip is the name of the extra field that I've created. I customize my timestamp in my service and store them as string in the output infotable.
in my case, i change my timestamp into HH:MM format asasdsd.jpg
Here is the result: HH:mm followed with the series and value:
LP_10027711
(To:HM_10184200)
i will try this! thank you
slangley
23-Emerald II
(To:MM_9023322)
Hi @MM_9023322.
--Sharon
slangley
23-Emerald II
(To:MM_9023322)
Hi @MM_9023322
We will be providing a fix for this in ThingWorx 9.3.4.  I don't yet have the release date, but it is estimated to be available in the next 2 - 3 months.
--Sharon
