How to color a single bar in a bar chart depending on a value from a different table?
RajatBain
9-Granite
I have a Bar chart on my mashup. That is showing few series of data. I want to change a color of a particular bar within a series in a bar chart, depending on a value that is stored in a different table. I tried to do some state formatting. But it is changing the color of the entire series. I just want to change only a particular bar's color. I am attaching an image for the reference.
Also is there any way to change color of bars from a service?
Thanks in advance.
1 ACCEPTED SOLUTION
Hi @RajatBain,
Which version of ThingWorx are you using ?
Starting ThingWorx 9.1.0 I believe you should be able to achieve that using the options introduced to define State-Formatting by Serie ;
4 REPLIES 4
Hi @RajatBain,
Hi @c_lowy
Thank you for your response. I am using Thingworx 9.1.0 and I don't see any option for state formatting for individual data series. I have state formatting option that is applicable for all the data series. Can you please tell me if I am missing anything and also, can you please share your data infotable datashape?
Rajat Bain
@RajatBain
Update the property value #NumberOfSeries to the number of series you have and you will get the state formatting option for all the series.
Sachin
slangley
23-Emerald II
(To:RajatBain)
Hi @RajatBain.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
