I have some device use MQTT Protocol, i want to use Service auto config MQTT Things. I already use GetConfigurationTable("JDBC Setting") to get infotable, but it's not work.
Hello @Nguyen_Khue
You can refer following community post to find a approach to copy configuration
Copy configuration from template to thing
I hope it helps.
Om Dukiya
Hello @Nguyen_Khue
I hope it helps.
Om Dukiya
Tks for help
I did it, but when i config password (String input), i't have problem: cant not conver String . How can i creat new password in mqtt config
