How to configure HA for Thingworx Connection Server
TL_10544753
6-Contributor
In my point, Thingworx HA Solution with PLC, Gateway does not Thingworx Application.
I have a question about the Thingworx connection server HA Solution, How to configure it,
Main PLC--Ethernet 2 Port
  • IoT Gateway PC1- Active
    • IoT Geteway PC2-Standby
  • Thingworx Connection server 1 Vms -Primary
    • Thingworx Connection server 1 Vms -Secondary
  • Thingworx Application (Application, Analytics, Database) 3 Vms
Hi @TL_10544753, not sure what PLC you are using but typically, it will work as PLC > Kepware > ConnectionServer > ThingWorx HA.
Where '>' indicates the connection relationship.
