In my point, Thingworx HA Solution with PLC, Gateway does not Thingworx Application.
I have a question about the Thingworx connection server HA Solution, How to configure it,
Main PLC--Ethernet 2 Port
Hi @TL_10544753, not sure what PLC you are using but typically, it will work as PLC > Kepware > ConnectionServer > ThingWorx HA.
Where '>' indicates the connection relationship.
