Hello there,
I need connect my EMS device (Raspberry Pi) to my Connection server (Also RPi). Is possible send data from EMS device throught CS to ThingWorx server? Is there also posibility to send REST?
Thanks everyone
I don't know if this is what you need, but take a look here: https://developer.thingworx.com/en/resources/guides/thingworx-raspberry-pi-quickstart
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
Thank you, it helps
