How to connect STUDIO to the COMPOSER?
pporta
6-Contributor
I want to hook up my AR experience to data modelled in the Composer. In the HELP section of Thingworx Studio I am instructed to.....
Configuring the Thing Template in ThingWorx Composer
1. In ThingWorx Composer, navigate to the thing template that you want to make ThingMark-enabled.
2. On the General Information page, search for and select PTC.ExperienceService.ThingmarkEnabledShape thing shape in the Implemented Shapes field.
Help: I cannot find the PTC.ExperienceService.ThingmarkEnabledShape when looking for it in the Implemented Shapes field.
Anyone out there that can point me in the right direction? I am running the free trial version of the Composer. I would be very thankful for advice.
BR Peter
dupatel
(To:pporta)
Peter Porta​: You need a ThingWorx extension ( ThingWorx VuforiaExperienceService Extension Package) which contains VuMarkEnabledShape(old)/ThingmarkEnabledShape Thing. This extension is not currently available on marketplace and has limited to PTC internal use.
Please refer to similar post for detail: https://community.thingworx.com/message/60905#60905
From the subject of the post it is not clear if you are not able to connect Studio to ThingWorx or need to see ThingmarkEnabledShape Thing.
-Durgesh
pporta
6-Contributor
(To:dupatel)
Hi Durgesh - thanks for replying so swiftly!
I am able to connect Studio to to ThingWorx - but the ThingmarkEnabledShape does not show up when searching for it in ThingWorx.
As a licenced partner to PTC I was hoping to get access to that extension - any idea how to get it?
I am currently running the Trial version of Studio and the Composer
BR Peter
dupatel
(To:pporta)
Peter Porta​: Currently, it is PTC internal and let me check with Product Management team to see if there are plans to make it public & if when.
-Durgesh
we would like to use the possibility for ThingMark-Enabled Thing like described above and in your Help Center.
http://support.ptc.com/help/vuforia/studio/it/index.html#page/Studio_Help_Center/UsingThingCodeEnabledShape.html
Is it possible to receive the  Vuforia.VuforiaExperienceService.VuMarkEnabledShape thing shape for enabling this feature?
Raphael
