I have 100 token created in Localization Table: Default', Now I want to convert and see in runtime whenever changed languages from dropdown in runtime.
Please suggest my any service or code which should convert to other languages automatically
You'll need to add the translation values in each of those languages. It does not do the translation for you. I would suggest using a service like Google Translate. Then open each language localization table you'd like to support and enter those values
- Nick
I would suggest creating a service that changes the language preferences of your user to whichever language you choose in the dropdown. You may need to refresh the page. You can use this service:
Users["myUser"].SetLanguagePreferences({
preferences: newLanguage /* STRING */
Hope that helps
- Nick
Hi Nick,
Thank you for your reply,
This Service, I am already using but the problem is.
I have added some new token in default as below
I have selected language in runtime from Dropdown list, refreshed browser and verified but its not converted in other languages.
Please let me know what is the issue?
- Nick
create another localization for required language and put all translated values in custom localization which is newly created . so that it available as table in system which can be used in mashup
