I've tried duplicating the data table entity in composer, but it did not copy the data over. If I use the service AddDataTableEntries, to import the data as an infotable, it does not copy the meta data. Is there a way to copy data including the meta data from a data table to another data table? I need a data table with the same data, but with a different data table name.
What metadata are you referring to here?
You can check the article CS330382 at https://www.ptc.com/en/support/article/cs330382
This article is for Stream, it should work for Datatable if you replace GetStreamEntriesWithData with QueryDataTableEntries of Datatable and AddStreamEntry with AddDataTableEntry of Datatable
Thank you for sharing the article. I will give that a try. By meta data, I meant timestamp, source, tags, etc.
I tried it, but I noticed that AddDataTableEntry doesn't have timestamp as a parameter. timestamp is a critical piece for me. I need to retain the timestamps from the entries in the source data table.
let id = Things["DataTableName"].AddDataTableEntry({
sourceType: undefined /* STRING */,
values: undefined /* INFOTABLE */,
source: undefined /* STRING */,
tags: undefined /* TAGS */
Hello @Willie
This can be done by using SQL database query. You can create a new datatable and also create a datatable with similar name in composer to be a duplicate of your source datatable.
Hope this helps! Pls let me know if you face any further challenges.
Bhawna
I found the following Postgres queries to work for this task:
Copying:
INSERT INTO data_table (entity_id, entity_key, field_values, location, source_id, source_type, tags, "time", full_text) SELECT 'TargetDataTableName' AS entity_id, entity_key, field_values, location, source_id, source_type, tags, "time", full_text FROM data_table where entity_id='SourceDataTableName';
Verifying:
select * from data_table where entity_id= 'TargetDataTableName';
