How to create Valuestream with script
SOLVED
Marble
Hi Guys,
I would like to achieve a following thing.
I would like to create a script wich will create a Valuestream and assign that VS to Thing from which the script is called.
I know how to create Things automatically, I dont know how to bend that code to create a Valuestreams.
Any ideas?
1 ACCEPTED SOLUTION
Highlighted
Re: How to create Valuestream with script
Hi Tomas,
  1. Creating a ValueStream it's the same as Creating a thing, the only difference it's the base template.
  2. Assigning a ValueStream to a Thing, as easy as: me.SetValueStream({ name: "value_stream_name" });
Best Regards.
Carles.
2 REPLIES 2
Highlighted
Hi Tomas,
Best Regards.
Carles.
Sorry should have try it on my own. It was easier than I anticipated.
Thanks a lot.
