Please help to create this graph
Hi @yasmalik
I think you can import "custom chart "extension from marketplace, it has bar chart, time series chart in it. In the bar chart you can select grouped, stacked as per your requirement. Check the image, download the extension from below link
https://marketplace.ptc.com/apps/216584/custom-chart-widgets-v303#!overview
Are you referring to the Proportional Chart Widget?
Hi @yasmalik
Hi @yasmalik.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
