How to customize widget with available tools?
Marcus_Konflanz
11-Garnet
hello friends, below the example of the result I want to achieve (image 1), and my current project (image 2).
I would like to know if it is possible with the available tools:
Add writing to the gaugeincrease
the thickness of the border (the option on the website as in the print is not working. as in image 3)
THANK YOU VERY MUCH IN ADVANCE.
1 ACCEPTED SOLUTION
Hi @Marcus_Konflanz.
Are you using the Progress Gauge?  We're not seeing the Line Thickness option from your screenshots.
It also doesn't appear that you can arrange the text as you have indicated in Image 1.
If you would to see some enhancements to this extension, please post your ideas on the ThingWorx Ideas page.
--Sharon
2 REPLIES 2
--Sharon
slangley
23-Emerald II
(To:slangley)
Have you found a solution to your issue?  If so, please post it here for the benefit of others on the community.  If you still need assistance, please provide further details of the issue.
--Sharon
