I have a localization table I use and by mistake I added few tokens, I want to delete them, they are on the default table.
I cannot find where I can do it.
TW version I use: 6.0.2-b456
Thanks.
A bit of a challenge, but there is a DeleteToken service that you can invoke using the REST API or in a mashup.
Thanks Pai Chung,
I'm not sure I fully understand how to do it, but I just want to say I meant how to do it in the composer, I dont want to do it from the code.
Unfortunately at this time there isn't a way to directly do it within composer, so you will have to do it by either building a mashup and using the DeleteToken service, or invoking it through the REST API.
Is there an example doing it using the REST API?
There are quite a few posts on REST API already in the community, as well as in support.ptc.com
the DeleteToken Service would have to be executed with a POST and needs an input parameter of 'name'
Hi Pai,
I am trying to delete a token using REST API, I am getting 200 OK message but the token doesn't delete.
Below is my service code, Could you please throw some light here?
var params = {
url: "http://localhost:8080/Thingworx/LocalizationTables/Default/ServiceDefinitions/DeleteToken",
content: {"name": ""+TokenName}
var result = Resources["ContentLoaderFunctions"].PostJSON(params);
Any help here is greatly appreciated.
Pai,
One more observation below.
When I tried to browse the URL http://localhost:8080/Thingworx/LocalizationTables/Default/ServiceDefinitions/DeleteToken
from Rest Client, I get the message "Editable System Objects Cannot Be Deleted", am I missing any setting or permission here.
Thanks for the help!.
Please try changing ServiceDefinitions to Services
Pai,
Changing ServiceDefinitions to Services did not work.
Actually when I browse for http://localhost:8080/Thingworx/LocalizationTables/Default/Services, I am not getting the "DeleteToken" service listed down.
However with http://localhost:8080/Thingworx/LocalizationTables/Default/ServiceDefinitions/ I see "DeleteToken" service available.
Praveen.
ServiceDefinitions is just that, all the defined services, to execute one, you need to use Services.
Praveen, try using this:
And as Pai suggested, another easy way is to do this via a Mashup with a text box connected to the Delete Token service of your Localization Table.
Perfect!
Thanks Ravi for complete URL.
As both of you said, deleting from mashup is easy. but anyhow now I know both the ways to delete tokens. Appreciate your help.
I guess now we can mark this question as "Answered".
sorry for english, i'm using Google Translate (Czech to English)..
Just delete text of token in Default localization table and save it. The token is removed. Functional in version 7.1.0.
