How to delete a token from the localization table
aelgov
I have a localization table I use and by mistake I added few tokens, I want to delete them, they are on the default table.
I cannot find where I can do it.
TW version I use:  6.0.2-b456
Thanks.
13 REPLIES 13
PaiChung
22-Sapphire I
(To:aelgov)
A bit of a challenge, but there is a DeleteToken service that you can invoke using the REST API or in a mashup.
aelgov
(To:PaiChung)
Thanks Pai Chung,
I'm not sure I fully understand how to do it, but I just want to say I meant how to do it in the composer, I dont want to do it from the code.
PaiChung
22-Sapphire I
(To:aelgov)
Unfortunately at this time there isn't a way to directly do it within composer, so you will have to do it by either building a mashup and using the DeleteToken service, or invoking it through the REST API.
aelgov
(To:PaiChung)
Is there an example doing it using the REST API?
PaiChung
22-Sapphire I
(To:aelgov)
There are quite a few posts on REST API already in the community, as well as in support.ptc.com
the DeleteToken Service would have to be executed with a POST and needs an input parameter of 'name'
Hi Pai,
I am trying to delete a token using REST API, I am getting 200 OK message but the token doesn't delete.
Below is my service code, Could you please throw some light here?
var params = {
    url: "http://localhost:8080/Thingworx/LocalizationTables/Default/ServiceDefinitions/DeleteToken",
    content: {"name": ""+TokenName}
var result = Resources["ContentLoaderFunctions"].PostJSON(params);
Any help here is greatly appreciated.
Pai,
One more observation below.
When I tried to browse the URL http://localhost:8080/Thingworx/LocalizationTables/Default/ServiceDefinitions/DeleteToken
from Rest Client, I get the message "Editable System Objects Cannot Be Deleted", am I missing any setting or permission here.
Thanks for the help!.
PaiChung
22-Sapphire I
(To:pbollu-2)
Please try changing ServiceDefinitions to Services
Pai,
Changing ServiceDefinitions to Services did not work.
Actually when I browse for http://localhost:8080/Thingworx/LocalizationTables/Default/Services,​  I am not getting the "DeleteToken" service listed down.
However with http://localhost:8080/Thingworx/LocalizationTables/Default/ServiceDefinitions/ I see "DeleteToken" service available.
Praveen.
PaiChung
22-Sapphire I
(To:pbollu-2)
ServiceDefinitions is just that, all the defined services, to execute one, you need to use Services.
Aanjan
(To:pbollu-2)
Praveen, try using this:
http://localhost:8080/Thingworx/LocalizationTables/Default/Services/DeleteToken?method=post&name=Your_Token_Name
And as Pai suggested, another easy way is to do this via a Mashup with a text box connected to the Delete Token service of your Localization Table.
pbollu-2
(To:Aanjan)
Perfect!
Thanks Ravi for complete URL.
As both of you said, deleting from mashup is easy. but anyhow now I know both the ways to delete tokens. Appreciate your help.
I guess now we can mark this question as "Answered".
droček
(To:aelgov)
sorry for english, i'm using Google Translate (Czech to English)..
Just delete text of token in Default localization table and save it. The token is removed. Functional in version 7.1.0.
