How to display warnings on Mashups?
AkshayKumar
How to Display Warnings on Mashups?
for eg. "Temperature is too high"
4 REPLIES 4
supandey
(To:AkshayKumar)
Hi Akshay, could you elaborate bit more on how you intend to display it, because there are quite a few ways how you can do it e.g. using LabelWidget, TextWidget, etc.
"LabelWidget"  sir!
Can you tell me which widget will be easier to display warnings?
supandey
(To:AkshayKumar)
Both Label and Value Display widgets are quite straight forward you just need the data bound to it however you want to do it and as you see screenshot below clicking on button widget on left shows the warning text over the right top one is ValuleDisplay and bottom one is Label Widget. Of course this is very basic example you can add conditions and so on as to when this should appear and the style associated to it. But it's a start
