How to do Rest API Client Authentication Through Certficate in Thingworx Platform
sarathi
My thingworx act as an client I need to get Data from third Party Server from REST API ( GET)  Using Certificate Based Client authentication, They given certificate Where do i save in Thingworx Platform
( Note : Am using Content Loader Function: Get Json Service)
1 ACCEPTED SOLUTION
supandey
(To:sarathi)
There is definitely documentation available, listing below some of them
-  Trust & Encryption - Hands On
ThingWorx setup SSL / HTTPS on Tomcat with Self-Signed Certificate
Configuring ThingWorx / Tomcat for SSL using a Signed Certificate from a Certificate Authority (CA)
-- Edit -- (Sorry missed to add this )
Above resources should help you get SSL enabled for Tomcat, it includes the step on how to setup the keystore which will be used by Tomcat. And my understanding is that you will need HTTPS enabled for Tomcat to make it a secure connection.
4 REPLIES 4
supandey
(To:sarathi)
Hi @sarathi is  you Tomcat running ThingWorx configured with SSL? If so could you test by installing this certificate in the keystore used by the Tomcat ?
sarathi
(To:supandey)
Hi @supandey  no i configured thingworx server in http port only , is there mandatory to configure tomcat to https port in order to do  certificate based client authentication ,
  If so how to store certificate in keystore used by  Tomcat, is there any document available?
supandey
(To:sarathi)
sarathi
(To:supandey)
I converted SSL Enabled Tomcat, i created keystore and imported keyfile in that keystore
Stil Content Loader Function through this error:sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target - See Script Error Log for more details.
You Can check this link:https://community.ptc.com/t5/ThingWorx-Developers/How-to-configure-Thingworx-as-a-client-with-certificate/m-p/566867#M30497
They said Content loader function unable to use certficates
Is it True? Content Loader function is not Capable to Perform certificate based client Authentication?
