How to do Rest API Client Authentication Through Certficate in Thingworx Platform
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
My thingworx act as an client I need to get Data from third Party Server from REST API ( GET) Using Certificate Based Client authentication, They given certificate Where do i save in Thingworx Platform
( Note : Am using Content Loader Function: Get Json Service)
- Labels:
Connectivity
Design
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
There is definitely documentation available, listing below some of them
- Trust & Encryption - Hands On
- ThingWorx setup SSL / HTTPS on Tomcat with Self-Signed Certificate
- Configuring ThingWorx / Tomcat for SSL using a Signed Certificate from a Certificate Authority (CA)
-- Edit -- (Sorry missed to add this )
Above resources should help you get SSL enabled for Tomcat, it includes the step on how to setup the keystore which will be used by Tomcat. And my understanding is that you will need HTTPS enabled for Tomcat to make it a secure connection.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @sarathi is you Tomcat running ThingWorx configured with SSL? If so could you test by installing this certificate in the keystore used by the Tomcat ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @supandey no i configured thingworx server in http port only , is there mandatory to configure tomcat to https port in order to do certificate based client authentication ,
If so how to store certificate in keystore used by Tomcat, is there any document available?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I converted SSL Enabled Tomcat, i created keystore and imported keyfile in that keystore
Stil Content Loader Function through this error:sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target - See Script Error Log for more details.
You Can check this link:https://community.ptc.com/t5/ThingWorx-Developers/How-to-configure-Thingworx-as-a-client-with-certificate/m-p/566867#M30497
They said Content loader function unable to use certficates
Is it True? Content Loader function is not Capable to Perform certificate based client Authentication?
