Hi Developers,
I added a "valuedisplay" widget to display image dynamically but image size is small even though I configured the setting to "show image scaled to width".
Could anyone tell me on how to expand an image in the widget ?
@Yoshihiko.N SourceURL attribute can be used for setting images dynamically in image widget. Please refer: https://www.ptc.com/en/support/article/CS208841
@Yoshihiko.N You can try increasing the container size for the value display widget by giving the MaxHeight and MaxWidth properties. Alternatively you can use image widget to display images on mashups.
Thank you for your super quick response !
-> I can do what I want to do. ( ^o^ )
-> I tried this but not sure how I can set image dynamically.
we need to set media (image link ) to the image widget but I don't know how I can get image link from media entities.
