How to generate xml file from data tables?
rsalunkhe
I want to generate xml file when user click on "submit". I want to generate xml for that specific data only not for whole column.
Rishikesh, take a look ContentLoaderFunctions in ThingWorx specifically at using PostXML function to see if that does what you need.
Hi Marek Nowaczyk​,
I want to generate xml file from properties which is changed in data table. Not for all data table xml will generate only for changed data(specific to one row only). Can this is possible Thingworx?
Hi Marek Nowaczyk​,
I want to convert only single record to xml. My desired operation required when data is changed that record is converted into xml file. How can this possible?
