How to get response in json
  • February 2, 2022
  • 4562 views
Thingworx/Groups/ getting html response
how can i get json response by using this api in thingworx
Best answer by nmutter
You need to add header
Acceptapplication/json
Then the response will be in json format. Not sure if this was the question.
What also works (but is not so nice) is to add "<host>/Thingworx/Groups?Accept=application/json" to the url. You can also add maxItems=<number> as by default only 500 items will be returned.
See page 54 in the attached manual - "Configuration API Service — Content Retrieval (JSON Response Structure)".
How to get Json result from Infotable in thingworx while using any rest api of thingworx
nmutter16-PearlAnswer
