How to ignore x-frame options header without chrome extensions
SK_10291683
3-Newcomer
Our XML file is not able to load in TWX without chrome extensions(X-frame options header).
Same XML file is working fine with chrome extension but it is creating dependency for the end users. We need solution where users can directly see the xml file from the TWX mashup.
I am assuming we need to make some update in the TWX xml file for the filter but based on all PTC articles we tried many filter options to bypass/ignore the URL(PTC articles followed: https://www.ptc.com/en/support/article/CS229450, https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Composer/Security/AllowingEmbeddedMashupsiniFrames.html#) and it did not work for us to solve this issue.
I have also attached the screenshot of the output with and without having extensions.
slangley
(To:SK_10291683)
Hi @SK_10291683
Since you've already reviewed the article and Help Center documentation, it would be best to open a case for this.  I will be happy to open one on your behalf if you agree.
What version of ThingWorx are you running?
--Sharon
