How to implement a login page in Thingworx, username and password values should be maintained in the database and after verifying the credentials the mashup page should be loaded.
psaxena
username and password should be maintained as properties of a thing and when user enters the credentials it should be verified and a mashup should be loaded on login.
kmagdum
(To:psaxena)
You can create an organization and while creating you can mention which mashup to be loaded as Home screen. ThingWorx will build a default login page for each organization.
An organization’s form page can be accessed with: <server name>/Thingworx/FormLogin/<Organization Name>.
For more details you can check ThingWorx Help Center.
Ketan
9 REPLIES 9
kmagdum
(To:psaxena)
Ketan
Hi Ketan,
Yes it worked. Thanks.
bkanipakam-2
(To:kmagdum)
Hello Kethan,
Is there a way to customize the login screen mashup?
Yogesh
Hi Yogesh,
You can customize the login page with logo, prompt and through style definitions. You can mention it while creating/editing the organization. The users which are available on the ThingWorx server and under the Organization can login through that page.
What is your requirement for customization?
Ketan
bkanipakam-2
(To:kmagdum)
Hello Kethan,
Thanks for the response. I want to customize as show in the attached image. I am able to format the background colors, login image, button and not able to format the background with an image/design. Can we customize as shown in 2nd picture with an image/text as water mark.
Yogesh
Hi Yogesh,
I don't think this customization is not possible with ThingWorx Organization Login Page. But let me check and get back to you.
Ketan
Hi everyone,
was a solution ever provided for this? I am facing the same requirement and would like to add a dropdown button to the Organization Login Page where the user can select the domain.
Thanks!
Francisco
CRArko
(To:fhernand)
Hi, Francisco.
Ketan's post above was marked as the correct answer for this. Try that out and see if it is helpful for you.
-- Craig A.
Thanks Craig,
that was the correct answer to create a login screen, but not to customize that login screen.
The last comment from Ketan was:
I would like to know if he ever found out.
