Hi all,
I have a problem on how to import google map location data from database.
The longitude, latitude, elevation are stored in different column in the postgresql database. I want to connect the database to the google map widget.
How can I do this?
BTW:
I know how to insert location data through Thing->Services (javascript) and extract location data also through Thing->Services to a datashape and bind the datashape to the google map. But now the location data will from columns of database? I am a little confusing.
Hi Tiantian Guo,
Please try something like:
// result: INFOTABLE dataShapeName : "MapData"
var result = Things["DBThing"].Service1(); // Change the ThingName and Service name here
var newField = new Object();
newField.name = "buildinglocation";
newField.baseType = 'LOCATION';
result.AddField(newField);
// location:LOCATION
var location = new Object();
var tableLength = result.rows.length;
for (var x = 0; x < tableLength; x++) {
var row = result.rows
; location.latitude = row.latitude;
location.longitude = row.longitude;
location.elevation = 0;
location.units = "WGS84";
result.rows
.buildinglocation = location; }
I hope it helps.
Hi Tiantian Guo,
Per my understanding; this will require conversion of longitude, latitude, elevation data to a Location Object.
Steps:
1. Read longitude, latitude, elevation Data from DataBase in an infotable.
2. Loop through the Table and convert longitude, latitude, elevation data to Location Object infotable. Example:
location.latitude = latitudeFromDataBase;
location.longitude = longitudeFromDataBase;
location.elevation = elevationFromDataBase;
3. Bind the new infotable to the Google widget.
I hope it helps.
Thanks Ankit. I am now doing like this.
But I now want to get a new column "location" from other three columns. I found some solutions. The grammar for thingworx needs to get used to..
Currently my code is like:
var params = {
infoTableName : "MapDataWithLocation",
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(MapData)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var buildinglocation = new Object();
buildinglocation.name = "buildinglocation";
buildinglocation.baseType = 'location';
result
got some errors.. still working..
And some loop like this:
for (i = 0; i < result.getRowCount(); i++) {
myfield.latitude = result.getRow(i).latitude;
myfield.longitude = result.getRow(i).longitude;
myfield.elevation = 0;
myfield.units ="WGS84";
result.getRow(i).buildinglocation = myfield;
Finally the code is no bug:
var params = {
};// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(MapData)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);var newField = new Object();
result.AddField(newField);var tableLength = result.rows.length;
var row = yourInfotableHere.rows;
//Your code here
row.buildinglocation.latitude = row.latitude;
row.buildinglocation.longitude = row.longitude;
row.buildinglocation.elevation = 0;
row.buildinglocation.units ="WGS84";
My input is a datashape.
The datashape is a output from the database.
But this code output is just fields of a new datashape. Where I get the data?... Really a newbie, sorry and thanks!
Hi Tiantian Guo,
result.rows
I hope it helps.
Dear Ankit,
It is really helpful. I think I start to understand the thingworx function now..
I change your code like this:
var result = Things["ExtractData"].extractdata(); // Change the ThingName and Service name herevar newField = new Object();
newField.name = "location";
result.AddField(newField);// location:LOCATION
var temp = new Object();
temp.baseType = 'LOCATION';var tableLength = result.rows.length;
var row = result.rows;
temp.latitude = row.latitude;
temp.longitude = row.longitude;
temp.elevation = 0;
temp.units = "WGS84";
result.rows.location = temp;
But the output like this:
something wrong here. But it really a big step for me. Thanks!
I think I get it. The result I get from table is "double". I need to convert it to double. Trying
Error like this:
really last step. I am trying.
Hi Tiantian Guo,
Could you please share the MapData DataShape here. Try changing the Datatype of latitude and longitude to number.
I have tried the code on my system and it works fine.
Also, I hope you have set the DataShape in the ExtractData DataShape.
I hope it helps.
Dear Ankit,
My code is finally like this and compiled successfully:
var result = Things["EThingName"].ServicesName(); // Change the ThingName and Service name herevar newField = new Object();
temp.latitude = "";
temp.longitude = "";
temp.elevation = "";
temp.baseType = "LOCATION";var tableLength = result.rows.length;
temp.latitude = row.latitude;//result.rows.latitude;
temp.longitude = row.longitude;//result.rows.longitude;
temp.elevation = 0;
row.location = temp;
But the output is like:
Something is wrong but no idea.
Any other thingworx masters have solutions on this?
Thanks!!
Could you please share Screenshot of fields in MapData DataShape.
The MapData datashape is no problem. I think..
Pleas move
inside for loop
other wise you are setting all the location field to one object and do the change on one object
YUanwu Shen
Ankit Gupta I see this thread has already been answered and Tiantian Guo has opened another for issue on NaN could you please have following discussion on that thread i.e. How to solve the NaN value in updated location field
Sushant
