How to increase Max file size for file transfers on 5.0 platform
jimfo
I'm calling the Copy service of the FileTransferSubSystem and getting an error stating that I'm exceeding the size of 5000.
I'm not sure where I can set this.
I'm using the 5.0 SDK to make the call from a c# application at the edge.
adam11
7-Bedrock
(To:jimfo)
Hi Jim,
You can increase the maximum file size for file transfers by navigating to the Configuration menu item on the FileTransferSubsystem.
jimfo
(To:jimfo)
Thanks. That worked. I just wasn't sure where to set the limit.
