Hello ,
I created a geofence using an infotable inside an infotable,i.e (outer infotable as columns id and location ,column location contains one more infotable along with columns again id and location region.).The location region column is with location base type and id has a GUID as base type.I need to increment a id value in outer infotable. So that I can close the geo fence set. Service as follows :
region = me.map_regionCopy;
if(!region) {
params = {
infoTableName : "InfoTable",
dataShapeName : "Region"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(Region)
region = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
//var result = region;
var params = {
dataShapeName : "shape_for_geo1"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(shape_for_geo1)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var newEntry = new Object();
//var i,n = 1;
for ( var i=1 in result.rows){
newEntry.LocationRegion = region; // INFOTABLE
newEntry.ID = i; // NUMBER [Primary Key]
// break;
i++
result.AddRow(newEntry);
But this is giving output as null infotable with column names where I can't see the data in infotable.
Bhargav.
Please check this code:
var params = {
dataShapeName : "location"
location1 = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
location1.AddRow( { id:"1", loc:"west" });
location1.AddRow( { id:"2", loc:"north" });
//logger.warn(" no of rows of location : "+location1.length);
var params1 = {
dataShapeName : "region"
var res = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params1);
res.AddRow({ id:1, location:location1});
var result=res;
It is creating a nested infotable with 1 row that contains an id and an infotable location.
Please use the above example for your requirement (my region datashape contains fields: id and location of type infotable).
Hope it helps,
Raluca Edu
Please use the following for instead of yours and adjust the values as you need (I don't like that you use i++ in a for loop):
for(var i = 0; i < result.length; i++) {
Hope it helps,
Raluca Edu
Hello Raluca Edu,
I tried the for loop suggested by you in my service, but still, the output is null, same as shown in the previous attachment.
Can you suggest me any other way or is there any problem in my code.
Bhargav.
var params = {
var params1 = {
var result=res;
Hope it helps,
Raluca Edu
Hi @Bhargav1.
If one of the previous replies answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
