I want to take backup of all my thingworx mashup or things which i made with the help of tortoise please help to integrate with thingworx please tell me step by step to do it easily...
Hi @yasmalik.
One solution....
In ThingWorx Composer, if you navigate to Resources > SourceControlFunctions > Services, you will find 2 services that can be used:
ExportSourceControlledEntities
ExportSourceControlledEntitiesToZipFile
You should be able to write a process for running a scheduled export using either of these services.
Please let me know if you have further questions.
--Sharon
Hi @yasmalik.
ThingWorx provides a mechanism for creating exports for source control systems. Simply select the Import/Export option. You will be presented with a choice for exporting Source Control Entities. Please refer to the Help for more information.
Once exported, it is a good idea to validate that all entities exported successfully.
If you still have questions, please let us know.
--Sharon
That right but I want to take my backup automatically by tortoise svn of the thingworx (is it possible ?)
Hi @yasmalik.
One solution....
--Sharon
Hi @yasmalik.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
