i have my application on S3 Bucket and the application's data is present in thingworx. Now i created some API which have the application data and i want to integrate that API's with the S3 Bucket to show the API's data on Application.
Suggest me the solution on this use case.
Hello @Ru ,
you can use REST API or the content loader.
pls refer the attached post:
Let me know if you have any further concerns
Regards
Bhawna
i refer the post that you have shared with me but i want to send thingworx api data on s3 bucket instead of sending a file from s3 bucket to thingworx through content loader.
Hello @ru
You are asking essentially how to access ThingWorx's REST API ?
There is plenty information about this in the ThingWorx Help Center and the ThingWorx Developer portal.
One example is this page from the Developer portal: https://developer.thingworx.com/resources/guides/thingworx-rest-api-quickstart
