How to link chart or mashup to Grid/info table data ?
GSPatil
11-Garnet
Hello Experts,
Good Evening...!
 I am looking for a method to link the Chart widget or another mashup to the values/parameters available in the Advance Grid containing info table data. Want your suggestions how I should get it done. FYI I am at beginner level about TWx platform
slangley
(To:GSPatil)
Hi @GSPatil.
I recommend contacting our Sales team for engaging with a Services person to assist you with your questions, or arranging for the training opportunities we have available.
--Sharon
slangley
(To:GSPatil)
Hi @GSPatil.
We're not clear on what you are trying to do.  Where is the data coming from to populate the Advanced Grid?  If you're running a service, you could use the same service for your chart.
Please provide more detail around your use case and we'll try to assist if the above has not answered your question.
--Sharon
Hi Sheron,
Thanks for your reply. The data is coming to Advance Grid  via a Thing with MSSQLServer Templete having a Service that contains SQL query to populate some columns (output selected as info table).
I want to link a chart for every parameter in first column of the data (here its Alarm) or to a entire row , so that by clicking on any instance of the alarm in first column or entire row I can see its chart page with parameters like active time, frequency, state, etc
You can refer the table given at this demo example on Demo Link  ( use username as TWDemoB & password as BestPlatform ).  Here as there is separate page linked to each row & opens on single click. I want to do exactly same.
GSPatil
11-Garnet
(To:GSPatil)
Hi Sheron,
Actually as mentioned earlier as I am new to ThingWorx Platfrom, I am unable to find the bindings or how its done in this demo. Hence you may say the issue is not resolved.
Also as I have installed the TWx foundation with MSSQL based 8.4.5 installer, I am unable to configure any widget in this by looking at tutorials. The only Grid is configured correctly & giving me data from SQL Database.
Is there any issue with a specific setting or issue with Persistence provider. Can PTC assist me with these types of  issue?
slangley
(To:GSPatil)
Hi @GSPatil.
--Sharon
Hi Sheron,
Thanks for reply. I got some resources on PTCLearningConnector that helped me. Also as per your suggestion, we are in process of arranging training soon.
Ganesh
