How to make that dropdown selected text in multi line(wrap)
Partha
I could not see the entire dropdown selected text in dropdown widget when selected text is lengthy,
is there any way to show wrap format in selected text in dropdown widget.
Partha
(To:yhan)
Hi
Thanks for the suggestion, but i am expecting only selected item in the dropdown , but i found   workaround for that issue.
workaround is
1) passing one more  html field for  dropdown display   field.
2) rendering html with formatting using Dropdown  List Render option
3 REPLIES 3
yhan
(To:Partha)
I didn't found a way about how to make selected text in multi-line dynamically, but how about using hint text instead?
Below image shows long name item text wrap, it's a little hard to read:
The below image shows using hint text instead
by using CSS code:
ptcs-list {
    overflow-wrap: break-word;
    width: 10rem;
    white-space: nowrap;
    overflow: hidden;
    text-overflow: ellipsis;
Partha
(To:yhan)
Hi
workaround is
mgoel
(To:Partha)
@Partha
If you feel previous response was helpful to resolve your issue then please mark that accept as solution for the benefit of other community users.
Mohit
