Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Everyone knows how I can generate an device-id respectively licenceRequestFile if thingworxs is not starting because the licence is not valid any more?
We renewed our licence and would like to activate thingworxs via offline-mode because we have a strict company proxy which we cannot deactivate and ptc don't think about implementing an proxy setting for communicating with the licence-server.
Anyone has an idea?
Please refer to this article https://www.ptc.com/en/support/article?n=CS271439
Let me know if this helps (or doesn't)!
That's absolutely not helpful! That was the first think I found and read before I createt this topic. If you know the article and read my problem you would know that I can not do what's suggested in the article because I cannot start thingworx, I quote....
If licenseRequestFile.txt does not exist(as mentioned in the article), use one of the following two methods for obtaining the Device ID:
and the logs also don't show my DeviceID or help in any other way. So what should I do know?
Hi @feil.
May I suggest that we open a case for this issue? If you can provide the ThingWorx version you're running, I will be happy to do so on your behalf.
--Sharon
I already opened a case C14956181.
I thought perhaps I'm not the only one with this problem.
Hi @feil.
Issues like this generally require an in-depth look at your machine requiring a WebEx, so most often will require a case.
I see that you're running the latest version of ThingWorx and you are correct that the Device ID no longer appears in the log for the latest releases.
Once the issue is resolved, if you could post the solution here, it would be most appreciated.
--Sharon
Yes. I think the second solution mentioned in the article CS271439 is to look into the logs. So it assumes that the device-id is outputted in the logs!?
Do you know a version where it's still outputted in the logs?
Why did ptc changed that, if now there is no other way to get the device-id???
Hi @feil.
I've reached out to R&D to find out why the Device ID no longer appears in the logs, but I think that change occurred with the 8.4 releases--possibly for security reasons. However, I thought of another way to get the Device ID. If you can forward your license file, I will check it to obtain the Device ID--assuming it was a commercial license and not a trial.
--Sharon
Hi.
I have the "old" device-id for the license-file. The problem is that I deleted the thingworxStorage and thingworxPlattform folders with the keystore in it. Is assume when I now install the thingworx and it creates a new keystore, a new id is generated and I assume that's different to the old one I have!?
Hi @feil.
Yes, I would expect the Device ID to be different under those circumstances.
At this point, you will need to work with the Tech Support engineer assigned to your case for resolving the issue.
--Sharon
