Hello guys,
I'm facing a strange problem.
There is a thing with some properties that have Alerts configured.
If I set manually some of these properties to "TRUE" the event of Alert works and the History populate normally.
On the other hand when a service manage automatically the Alerts, the properties change, the Alerts be active, but the history doesn't populate the infotable.
Could you help me, please?
Thanks.
Christyam
What do you mean by a service manages it? What does the service do?
Did you check the log for any error messages?
Thanks @PaiChung
Well, imagine a property that has an alert configured and its name is "Property1".
Now, imagine a service named as "Service1" that has some "if/else" and an attribution like "me.Property1 = true;".
My symptom is, if I manually put "true" to "Property1" the alert is activated and when I test the service "QueryAlertHistory" the infotable is normally populated.
If I let "Service1" run, "Property1" changes, but the Alert History doesn't populated as well.
I checked again the Monitor and there are no errors related.
That sounds like a bug, because that seems to imply the Alert isn't firing, or perhaps even data change isn't firing.
You can test if datachange is firing by just creating a subscription and putting in a logger statement.
I would put in a support ticket.
